Benchtop Measurement and Test
High-Performance Test
Systems Engineering Software
10-01-2015 04:02 AM
Hi All,
I have been trying to run a simulation of 74LS75 D Latch. Here is an image of my simulation:
For some reason, the simulation does not work correctly (as seen from the current reading of 1.776 uA). What am I missing here?
10-02-2015 11:26 AM
Hi Smetho,
Welcome to our forums!
What is the specific problem that you are experiencing?
If you want 1Q1 to follow 1D1 the enable signal must be high. In this case the enable signal is 1LE and not 2LE. The enable 2LE is for the latches 2 and 3.
Is this helpful?
Andres G,
NI
Thanks!
We'll be in touch soon!
