Multisim and Ultiboard
Summing amp with modulation problem
I am trying to simulate a siple circuit with 2 modulated signals going into a summing amplifier in multisim. However, as soon as I put in the op ap the output voltage increases up to the rail voltage. Before adding the opamp the signals seem to be adding correctly after modulation. Thanks!
(5,012 Views)
It is better if you post the Multisim file instead of the screen shot.  The Multisim file has information that does not appear on screen shot.
Tien P.
(4,990 Views)
