02-12-2012 07:37 PM
I have two identical subcircuit symbols. One is just fine, but the other has pins that do not align with the MS grid, and one that will not even connect. MS12.0.0.
This one is fine:
This one pins are off grid. The circled one will not connect.
Solved! Go to Solution.
02-12-2012 08:02 PM - edited 02-12-2012 08:06 PM
If I delete the bad symbol and copy and paste the good one in again the pins all line up fine. But then all my subcircuits refdes are scrambled. At the rate MS can change redes values I will need about 4 hours just to get it back the way it was.
I have seen this problem in many versions of MS, but usually it doesn't get so bad the pins won't connect to wires.
This happens after adding a pin to the subcircuit. I can't see any way to fix it editing the symbol.
02-13-2012 03:02 PM
This is an issue I have seen on some occasions. One thing you can try is to rotate the symbol in the symbol editor. I have seen some instances where that has actually aligned all the pins. Otherwise, the best option would be just to re-draw the symbol.
Hope this helps.
02-13-2012 07:54 PM - edited 02-13-2012 07:54 PM
I don't see any way to rotate the symbol. If I select all and rotate it always complains something is moving outside the boundary box and won't do it, even if I resize the box to be large and square.
I also don't see how to re-draw the symbol. It's created automaticaly when I design my subcircuit.
Can you be more specific?
Thanks.
02-14-2012 03:23 PM
I have been experimenting a bit with this. One thing you can try is open the Symbol Editor, select the pin which is not connecting and then from the spreadsheet view, change the Shape to Zero-length Pin. Then try to see if you can connect the pin in the design. It will not appear as a line but you should still be able to connect to it.
If this does not work, you can open a service request and we can try to see how to resolve the issue.
Hope this helps.
02-14-2012 05:39 PM
That got the pin that was way off to where the others are. Even though they are still not quite on grid it is able to hook up.
All that is needed is to change the pin type to anything else and then change it back.
David B
