07-14-2007 08:59 PM
07-15-2007 09:33 AM
07-15-2007 03:34 PM
10-28-2007 12:34 PM
10-28-2007 01:24 PM - edited 10-28-2007 01:24 PM
Yes, you are correct about that Euler and from now on I will do that because not everyone is experienced in creating components and this will eliminate any problems that may be created by trying to make a component from the model file. The only thing is that the person will have to tell me which version they have, because older versions can't open newer version files. Since I have Version 2001 also this shouldn't be much of a problem.
Thanks a bunch for that.
I am unsure about your last question. Did you want the 2N3055 from Version 2001? I am just wondering because Version 10 has a 2N3055A that I am sure would be comparable to the staright 2N3055. Unfortuantely, I checked both versions and there is no 2N2955 in either one.
Message Edited by lacy on 10-28-2007 01:35 PM
10-28-2007 01:30 PM
10-28-2007 01:52 PM - edited 10-28-2007 01:52 PM
Message Edited by lacy on 10-28-2007 01:58 PM
10-28-2007 08:39 PM
12-04-2009 06:55 AM
lacy, hello!
If it is possible, could you please do the same thing for TIP41A, couse I don't have it in my Multisim, and I really need it.
Thanks in advance! 🙂
