07-08-2015 03:04 PM - last edited on 07-09-2015 03:16 PM by LiliMcDonald
Hellooo All,
I would appreciate if someone helped me with the readings of the analyzer
I have attached to this posting. I'm not even sure if the ckt is correct
and would appreciate your response please.
Thanks for viewing,
07-09-2015 04:20 PM
Hi renegadeg,
For the future one post per topic should suffice.
The circuit appears correct. The output from the word generator are all low - this can be seen on the logic analyzer on the first four rows. This corresponds to a high output from the logic circuit, which is seen on the analyyzer on net 18.
Jeff
07-09-2015 04:54 PM
I appreciate your reply. I just decided to go for Basic components like a battery and 4 input switches for ABCD. Then Bulb outputs. And its worked.
I have attached for your Viewing.
Thanks Very much Again
07-09-2015 04:58 PM
Glad at it worked. Just as an FYI we added several new probe types in Multisim 14.0 including digital probes which make viewing and analysing digital signals much easier and intuitive.
Jeff
07-09-2015 05:01 PM
I have the student vversion 13.0. It's prety basic. The version 10 we use in college is more advanced then the 13.0 I currently have.
Thanks again very much
