11-15-2013 03:54 PM
I have simulated the circuit from ECG Amp with ECG signals and it works properly.
But I opened a new page and built all the circuit again by myself and the result was not the same but much much worst. I copied the circuit from the downloaded example and paste it into a new page and didn't work fine either.
Then, What is the problem?
I attach the document for a kind person that could help me .
Thank you in advance.
11-15-2013 03:58 PM
Excuse me, I forgot to say that there are three circuits in the page , if you delete the last one , the message of the parallel sources will not appear.
Regards.
11-20-2013 09:26 AM
Hi there,
I opened your circuit file, copied and pasted the top circuit in a new file, replaced the ECG Signal instruments and got this result:
I'm attaching this circuit. Give it a try and let me know how it works.
11-21-2013 08:06 AM
Thank very much you for your answer. It works properly now.
I plan to make this circuit in a protoboard and prove it with electrodes and oscilloscope, is it save?
Regards.
11-21-2013 09:12 AM
My best advice is to make sure you calculate and measure the expected currents and voltages. After building the prototype take real measurements to double check that everything works as expected.
11-23-2013 10:16 AM
Hi again,
Thank you for the advices. I've also thought on an isolating circuit, but can't find where to buy one. For example I search on RS or Farnell : ISO 100 and nothing appears. What solution would you suggest me?
Again, thank you for the answers, they are helping me so much.
Regards.
11-25-2013 11:00 AM
Unfortunately I'm not familiar with these type of applications. Perhaps you could do more research on the use of optocouplers for these circuits. I found this article that discusses patient protection circuits, hope it helps.
11-28-2013 07:26 AM
Thank you.
We have proved without isolation, with a battery and there is too much noise, can't see the signal, we'll prove to add filters.
02-15-2015 06:36 AM
Please tell me that in your file " New.ms11 901 KB" it is not working, error of missing file "USER_ECG_Electrode" .
Please share ECG Signal file which you has replaced in the ab0ve circuit. i am usung MULTISIM 11. And i need ECG Signal.
please reply
02-16-2015 04:00 PM
Hello Xam1122,
I could't run the circuit in a protoboard. However, it works properly as a simulation. You can find all the instruction to simulate the ECG signal in the following web: http://www.ni.com/example/30925/en/, this web contain the same circuit that you are trying to open.
I hope this info can help.
Regards.
