09-30-2013 07:36 AM
I am not able to simulate the ECG signal in Multisim and I am working with Multisim version 11.0.1 and I downloaded the package and when I opened it it says error "Cannot find the LabVIEW instrument "LVInstrIF820/ECG_Electrode". The following instrument(s) will not work properly:XLV1".Even though I have saved the LLB file in Ivinstruments it displays this message.Please help me out with this problem.
09-30-2013 09:56 AM
Just to confirm, are you tryin to run the example files from the tutorial:
Biomedical Application: Multisim Simulation with an ECG Amplifier
What's your operating system?
09-30-2013 12:15 PM
yes and my operating system is windows 7
09-30-2013 02:27 PM
Since this instrument was created with LabVIEW 8.2.1, you need to install the Run-time Engine the for this version. Click here to download it.
After downloading and installing the LabVIEW Run-time Engine open Multisim and see if you can select and place the ECG Signals instrument.
Let me know how this works.
10-01-2013 04:07 AM
Thank you very much it is working fine .I have got one more question that the instrument XLV1 is producing the waveform or we need the circuit also to get that waveform?
Since we have developed a circuit for extraction of ECG signal and we need to input the ecg signal in order to simulate it and check whether the circuit work or not....so whether I need only just the instrument or total circuit?
and even when I simulate the current one the simulation is very slow....can you explain a little bit about the circuit and its functioning and if I need a 3 leads circuit where do I connect the pins in that instrument.
10-01-2013 10:53 AM
The ECG Signals instrument simulates a raw ECG signal and you can select different points of measurement (for instance: Righ leg, Right arm, etc). The controls available in the instrument allow you to change the behavior of the signal, add noise, etc.
In the example we are testing the amplifier circuit with the ECG Signals instrument, which is the input to the circuit. If you designed your own circuit you can simply place the instrument and connect the corresponding inputs.
In order to improve the simulation speed go to Simulate>>Interactive simulation settings. Check the Maximum time step (TMAX) box and enter 0.0005, click OK and run the simulation. The simulation will run faster, however you will lose precison.
10-03-2013 07:15 AM
Yes I got it.What we have implemented is the following attached file but we have also used simple amplifiers but we couldn't get the output.Can you please review the circuit and tell me what was our mistake.I even attached the circuit diagram of our implementation (It is downloaded from a website).
10-03-2013 02:34 PM
Here are some recommendations:
I took a look of the website where you downloaded this design and it seems that initially the circuit was designed to work as a single wavelength pulse oximeter with the help of LEDs, therefore, I'm not sure if the circuit will work with the ECG instrument because of the nature of the signal. I recommend you to read in detail how the circuit works.
I tested the first two stages of the circuit, the virtual ground circuit and the pre-amp:
I also attached this circuit here.
10-03-2013 02:55 PM
actually it even works with ECG signal.In the same website he has posted videos in which the same circuit works for both and after acquiring the signal he does the denoising using some software.
10-20-2013 09:35 AM
We are taking a ECG signal(MIT-BIH database) and we need to process the signal using an algorithm and it should be processed in a processor.Can you please give me the details of any algorithm to be used and in which processor is the best to use for processing the algorithm and that processor should be having less power consumption and more speed.
