hi everybody.
i am working on an ECG project, so as a first stage i must design the ECG sensor, my project will need also labVIEW later on, so i download the ECG virtual signal which can be found by pressing on the labVIEW icon inside MULTISIM but what ever i try any circuit i didnt find the solution for the output. plzzz i need help any advice will be thankful.
i will post down what i did so far, by the way the ECG generator have to change the common mode=4.8 and the frequency=8
then if you chose the oscilloscope next to the ECG signal, can see the pure signal BUT at the last oscilloscope there are nothing. i used many types of op-amp but nothing can work.
