Multisim and Ultiboard
Newbie...Need to add a connector with 120 pin (double row 2X60), .039 pitch, .062 thickness
All
I need to design a PCB to receive this add on card (http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName=en543132).  I need to connect to the PIC Tail plus connector.  This goes into the development board (http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName=en024858)provided by microchip at J3 (black header, part number MEC1-160-02-F-D-EM2 from samtec)
Another option is to design a PCB to connect at J9 (120 pin (dual row 2 x 60), .039 pitch, .062 thickness) of the above development board.
However there is no connectors available in Multisim to do this.  How can I do it.  I am pretty new to Multisim.  One more note, we can't handle surface mount and hence looking for through hole.
Aravind
(3,024 Views)
Unfortunately I think you are stuck with the surface mount part.
Have you thought about using an assembly surface to populate your board?  I'm pretty sure they'll do just a portion of it for you if the expense is an issue.
(3,015 Views)
Hello
This is part of a design and manufacturing class I am doing at a county college. I am required to designed and manufacture a PCB and the college can't handle surface mount.
Are you suggesting to give it outside and get it done?  That is not an option for reasone explained above.
Any suggestions
Aravind
(3,011 Views)
