03-24-2009 03:30 AM
Hi
Anyone experienced that Multisim doesn't open Ultiboard then trying to transfer to Ultiboard? I can open the oputput file(.EWNET) manually in Ultiboard but then I can't forwarad annotate if I change anything in the design. I've tried to uninstall multisim 10.1 and install it again with no succcess. Is there any "linking" software that handles the communication between multisim and ultiboard that doesn't work?
//Johan Hansson
03-24-2009 07:26 AM
I've also tried to rename folder
C:\Documents and Settings\USER\Application Data\National Instruments\Circuit Design Suite
to
C:\Documents and Settings\USER\Application Data\National Instruments\Circuit Design Suite_old
and then repaired the installation without any success.
03-24-2009 09:08 AM
Hi Johan,
Multisim is supposed to launch Ultiboard automatically when you export or forward annotate to Ultiboard. I was unable to reproduce the behaviour that you are describing. Can you tell us what operating system you are running? Has this ever worked for you in the past? Did you try updating your Multisim? There is a 10.1.0.1 update for everyone and 10.1.1 update for those with SSP.
As an alternative, I can suggest the following work around:
Unfortunately, I can't help you any further, but someone from tech support may.
03-24-2009 09:28 AM
Hi yyao
I'm running WinXP Pro SP3 and it have worked before (with SP2). Multisim version 10.1.197
Using the work around worked fine but it would be nice if multisim open ultiboard.
03-24-2009 09:57 AM
03-24-2009 10:52 AM
My computer also doesnt transfer to Ultiboard from Multisim.
running XP pro SP3 .
Multisim + Ultiboard 10.1.1.
(didn't transfer with 10.1 or 10.0.1 either (all on SP3))
I'm guessing SP3 messed it up, like M$ is SO skilled at doing.
I dream of the day when M$ uses a fraction of its bazillions to make a working product.
03-25-2009 02:43 AM
04-09-2009 01:40 PM
Hi guys,
We tried to reproduce this problem but couldn't get it to happen :(. We've tried different combinations of software configurations, but this problem just wouldn't come up. We will keep an eye out for this problem and will try to fix it if we can get this problem to come up. Just to check, you guys are doing the following right?
In the mean time, the best thing that we can suggest is to reinstall both Multisim and Ultiboard. If you have done that already and it doesn't work, there is a workaround posted above.
Keep us posted if anyone finds out anything else about this problem.
Thanks!
04-14-2009 04:44 AM
Yes yyao, that's exactly what I do. And it begun after upgraded to WinXp SP 3 from SP 2.
Computer
Dell Latitude D620
Intel Duo core @1,66GHz
1G RAM
Software
NI Curcuit Design Suite v10.1
04-14-2009 08:56 AM
Hi Johan,
Thanks for that information. We did try to install SP3 after SP2. However, Multisim was able to launch Ultiboard fine for us. In fact, we have tried other combinations of installations if service packs and Circuit Design Suites and updates as well, but we weren't able to get the same behaviour. I suspect this may have to do with the combination of other software potentially installed on your (and others') machine.
We'll keep an eye out for this, and please keep us posted with any insights to this problem if possible.
Thanks!
