01-02-2013 09:12 AM
Hi Ganesh,
Spice models for parts are developed by the manufacturers. I searched intersil's website but there is no spice model available for this part. This is basically a voltage controlled function generator which you can easily simulate using some of the voltage controlled sources provided in the Multisim Database. Go to the Sources Group and the CONTROLLED_VOLTAGE_SOURCES faimily. You can find voltage controlled sine/square/triangle wave generators.
Please start a new post in the future when you have any questions or repy to a related one.
Hope this helps.
01-03-2013 07:11 AM
Thank you very much sir,will try out this.
regards
Ganesh
05-17-2013 11:47 AM - edited 05-17-2013 11:54 AM
Good afternoon
I apologize using Google translator
assembled circuit on the power supply NCP1014, replacing the diodes D1 or D2 on DIODE_RATED with sufficient par, component failure occurs, for example D1 1000V, please tell me where the mistake, or maybe there are any features of the application components RATED_VIRTUAL.
Thanks in advance.
12-19-2013 07:03 AM
Hi fernando
please could you help me to gett software for multisim and labview i tried to make dowload but i couldn't.
Rgds
Antonio Lourenco
12-30-2013 08:41 AM
Hi Antonio,
The links where you can download Multisim and LabVIEW are below:
http://www.ni.com/multisim/try/
You can find the instruction to download and install Multisim here:
http://www.ni.com/tutorial/14581/en/
