06-22-2015 06:20 AM
I made a transient analysis of a 4-stage-amplifier with a certain input pulse generated with a piecewise linear voltage source (screenshot 1).
Now I want to make a parameter sweep analysis by varying the maximum amplitude of my generated pulse.
What's the right parameter for this? (screenshot 2)
Thanks in advance,
Johannes
06-23-2015 03:05 AM
Dear Tintifax,
could you please post your Multisim circuit diagram.
Kind Regards,
OGS3 | Applications Engineering | National Instruments | NIG |
06-23-2015 04:19 PM
Hi there,
You will not be able to do it by sweeping device/model parameters because the Amplitude of a pulse source is actually not considered a device/model parameter.
Use Mutlisim's Circuit Parameter feature for this. See the attached circuit for reference.
I defined a new Circuit Parameter (View->Circuit Parameters) called "Level" with a default value of 1.
I assigned this parameter to the "Pulsed value" parameter of the Pulse Voltage source component.
Then, in the Parameter Sweep dialog, I selected Circuit Parameter as the type of parameter I want to sweep and then I selected the "Level" parameter.
Let me how that works out for you.
06-24-2015 09:47 AM
