09-12-2009 09:38 AM
Hi all,
I am trying to create a new component, AD8302, in NI Multisim. The SPICE model I already got from Analog Devices website.
Now I am following this instruction :http://zone.ni.com/devzone/cda/tut/p/id/3173
However, in Step 4: set pin parameters, I have a problem setting Type of the PIN: having read the datasheet, I am still confused don't know which [area
parameter I should use for each pin.
In other word, could anyone help me to explain what are the differences between: passive, ground, bidirectional, input, no connection, output and power
Dennis
09-14-2009 09:13 AM
Hi Dennis,
The meaning of these pins is summarized in the Multisim help file. Click Help>>Multisim Help. Click on the contents tab of the Help browser and nagivate to Schematic Capture - Advanced Functions>>Electrical Rules Checking>> ERC Rules Tab. There is a table on this page which summarizes the function of each pin type.
Note that these parameters are only used for ERC. They will not change how the component behaves in schematic capture, simulation or layout.
Hope that helps.
09-14-2009 09:34 AM
11-27-2013 10:44 AM
Hi Dennis. Do you still have the model of this device? I can't find it.
THank you.
05-21-2014 03:04 PM
Man, how did you find the model for the AD8302?
Thank yoU!
08-09-2017 05:46 PM
I'm working on a project that also uses the AD8302 and I'm having the same problem. Were you able to create the integrated circuit to run in MultiSim? Could you help, sending me the template available?
04-30-2018 05:06 PM
Hi Dennis,
I'm interested to do simulations at multisim with AD8302, you were be able to make up the model? Can you send me? Thank's for tour attention!
Best regards
Allan Nascimento
