05-25-2009 11:19 AM
Here are two ms10 files.
IR_38f-0.ms10
IR_38f-1.ms10
"IR_38f-1.ms10" crashes while "IR_38f-0.ms10" is ok.
I can open "IR_38f-1.ms10" by double-click this file,
but when I edit anything on it, it crashes.
it will crash by "open ..." menu instead of double-click.
but the file "IR_38f-0.ms10" is fine.
The only difference is that "IR_38f-0.ms10" has a U11A (a NOT gate)
on the right-bottom corner. I deleted this gate and save it as
"IR_38f-1.ms10", but the file seems damaged.
I have test it for several times, the result is always the same.
In fact, it seems that the new file will crash if I delete anything in file
"IR_38f-0.ms10" and "save as" it.
Wierd? It makes me crazy! Please help me!
05-26-2009 12:46 PM
Anyone help??
05-28-2009 10:50 AM
Hi coocoo,
The crash is induced by problems related to component U1 - 27C64-12L. This has been fixed internally and should not manifest itself in future releases. For now, what you can do is replace component 27C64-12L with component 27C64-12P, which has the same parameters except for the footprint.
Let me know if you run into any more issues.
05-28-2009 02:42 PM
05-28-2009 02:45 PM
