08-24-2009 01:24 PM
I´d like to know wich levels of MOSFT modeling are supported in Multisim and if the spice language used is the standard one.
Have a nice day!
Solved! Go to Solution.
08-24-2009 08:29 PM
Hi Morara,
You can find a list of the currently supported models/levels in the Multisim User Guide. You want Chapter 7 Multisim SPICE Reference > Analog Devices > MOSFET.
Unfortunately, there is no standard SPICE language. Multisim's implementation is based on XSPICE with some additions, however, Multisim supports compatibility modes that allows you use tell Multisim that a SPICE model was written for a particular simulator, and to use the syntax for that simulator. This can help use models designed for other simulators. As a general rule, if it is an analog model, it is likely to work unmodified in Multisim. If it is a digital model written for XSPICE, it is likely to work unmodified in Multisim.
