04-26-2015 07:42 AM - edited 04-26-2015 07:43 AM
Basically, when I use logic analyzer to show timing diagram of my logic circuit, it gets to about 1/4 of the screen then scrolls forward by itself:
and then
this is very annoying, how can I fix this?
04-26-2015 07:55 AM
I just tried using an ordinary oscilloscope and it does the same, it just starts over for some reason
04-29-2015 09:01 AM
For a scope, there is a button "single" click on it and the simulation will pause once the signal reaches the right side.
The Logic analyzer does not have this option; it will stop once it reaches the max samples . You can adjust the Clock/div as view more data while the simulation is running. You can also use the Grapher under the View menu. The Grapher screen will change the scale as it receives more data.
04-30-2015 03:39 AM
Thanks but I needed something else: In interactive simulation settings I had to check "continue without discarding previous data" option, and now it works as intended!
