01-20-2010 07:15 AM
Hello. I use the MS 10.0.343.
When I load simulation settings from a previous Parameter sweep - only some of the settings are correct.
The MS design is attached (see Cobra).
See JPG Simsettings_Correct. This is how it should look. I now save the simulation settings - and reopen:
See Simsettings_Load_Incorrect. Note that Device type has changed back to BJT. It should have been Vsource. The start/stop points for Vsource are correct.
Is this a bug or have I forgot something?
W.k.r.
Solved! Go to Solution.
01-20-2010 07:26 AM
01-20-2010 08:12 AM
Hi Eric,
I was able to reproduce the problem your describing in 10.0.343. I checked in the latest released version (11.0.278 ), and it seems to be fixed in that version.
