02-24-2015 10:46 AM
Hi all,
I recently installed multisim 13 on a new computer. I went to do a simple single frequency analysis of an RC circuit and got some funny results. The magnitude of the voltages measured by the probes seem to be off, and I have never experienced this on any other computer I have used. I have tested it in multiple circuits and always get the same problem. I was wondering if there is some setting I am missing that will change this, but I have searched forums for two days now and haven't come across this particular issue. I have attached some images to show what I'm describing.
Thank you
03-10-2015 10:02 AM
Double click the AC source and check that your AC magnitude setting is correctly set, by default it is set to 1V.
