02-19-2013 09:41 AM
Thank you for taking time to reply.
Noted for the FET part.
Well, yes I've come to understand that it is typically a DC supplier. Is there a modification that I can do to output an AC signal? ( I tried removing the diode and capacitor, thinking that it is the rectifying component of the circuit. I must've gotten it all wrong?). Please advice.
Again, thank you.
02-19-2013 10:07 AM
My suggestion is to start with ideal switching components (for the transistor and diode).
Please see attached a working flyback producing 6V from 12V.
I suggest you familiarize yourself with flyback converter theory before running simulations. After you've done that, then you can play with the simulation parameters such as switching frequency, magnetising inductance, load resistors and others to see their impact on output voltage levels, ripples, CCM/DCM modes, etc.
Here's a great pdf from a book:
ecee.colorado.edu/~ecen4517/materials/flyback.pdf
03-07-2013 01:21 PM - edited 03-07-2013 01:22 PM
Thanks for the suggestions. I see the mistakes I've made with my flyback now.
Although, in the attached circuit, I do not understand why you connected at +10V to the Rload.
03-07-2013 02:12 PM
+10V is just a connector name. I am not actually driving that node with any voltage.
However that connector name should actually say "+6V" since the flyback generates 6V.
10-30-2013 02:43 AM
Hello Can you decipher the transformer parameters: PARAMS: np = 16 ns = 1 lmag = 10m lleakp = 0.1u lleaks = 0.1u rp = 1m rs = 1m
10-30-2013 09:57 AM
Hi there,
These are parameter in the SPICE model and I am not sure exactly how or why you are setting those directly. The component in the previously-attached file has a GUI with proper parameter names. Perhaps you are referencing some other component.
But to answer your question...
np - number of primary side turns
ns - number of secondary side turns
lmag- magnetising inductance
llpeak - leakage inductance on primary side
lleaks - leakage inductance on secondary side
rp - coil resistance on primary side
rs- coil resistance on secondary side
12-09-2013 11:02 AM
Just a quick question...how is the inductor right before the transformer being used in the circuit? Also, could someone please advise on how to go about adding fuses? (where and how to determine which rating to use?)
Any help is greatly appreciated!
Thanks 🙂
10-24-2014 07:39 PM
I had the same problems, fortunately I found a Simulink design that helped me build the circuit.
http://www.mathworks.com/help/physmod/elec/examples/flyback-converter.html
02-16-2017 02:10 AM
while simulating showing error,Please suggest me the solution..
