08-26-2015 04:25 AM
08-26-2015 06:42 AM
How about placing zero ohm resistors where you want to place jumpers?
08-26-2015 07:03 AM
08-26-2015 07:08 AM
With 0 ohm resistor, you can place the part, if you want a jumper, if you want to remove the jumper you take out the part. You can do this with TH or SMT, what more do you need? With the pads you can even just use a piece of wire.
08-26-2015 07:13 AM
08-26-2015 07:19 AM
Oh, you just want to bridge two pads with a solder blob. Yeah I have seen this done, but I do not know of any footprint in the library. You will probably have to make our own,
08-26-2015 07:23 AM
08-26-2015 07:27 AM
The semi circle is what I have seen.
08-26-2015 08:45 AM
I found this example for jumper pads like you want. The spacing is about 6 miles.
08-26-2015 08:46 AM
I meant mils, not miles.
