11-24-2014 01:02 PM
Hi Everybody,
I'd like to know if there is some way to separate the source and the measured current and just writte an mathematical expression to make a dependence between the source and the said parameter. Thanks in advance.
11-26-2014 10:29 AM
11-27-2014 12:15 PM - edited 11-27-2014 12:17 PM
Sure,
Here is the deal:
I'd like to build a circuit with dependent sources, but instead of connecting the sense of current/voltage, I'd like to know if there is a way to writte a sentence for the source which is dependent of a parameter.
For example:
In this circuit I just wrote an expression for the source and its respective parameter. (8*Io).
11-27-2014 02:16 PM
Typically Spice simulators handle that situation by placing a zero voltage independent source in series with the 5 ohm resistor. The current through that source then becomes the controlling current for the dependent source. If you need a more complicated expression than a constant multiplier, look at the non-linear dependent sources (B devices in Spice 3).
Lynn
