11-25-2009 09:13 AM
I designed a 4 layer board and later was required to change a number of parts' foot prints.
I forward annotated the new data from Multisim and lost the two inner layers of the design (or so I thought).
I reconstructed the two inner layers from scratch, saved and closed the design.
Upon opening the file the next day, I discovered two extra "recovered" layers. Now my design has 6 layers.
I tried deleting the recovered layers, but I can't do it without losing the drill information as well.
Is there a safe way to extract the recovered layers from the design without losing the drill info?
Thanks very much, Tod
Solved! Go to Solution.
11-26-2009 09:48 AM
Hi Tod,
"Recovered layers" are created on opening a file if Ultiboard find objects that are referencing layers that do not exist in the board. Generally, it should be safe to remove these layers in the PCB Properties dialog, as these objects are typically pieces of copper. First you will need to remove all objects from these layers. One easy way to do this is:
(I feel like I might be missing here, and if so, let me know).
11-27-2009 03:40 PM
Thank you very much Garrett, I was able to remove the actual data from the recovered layers without removing the drill information from the design! Unfortunately, the "delete" function of the edit menu is greyed out, so I can't remove the layers from the design toolbox. Tod
11-27-2009 07:27 PM - edited 11-27-2009 07:29 PM
You are correct, delete does not delete layers. Instead, you need to change the PCB properties to remove the layers.
