Multisim and Ultiboard
How to export spice model from master db
I can't find a menu option nor DB manager option to select a component and export the spice model. Msim 10.1 full academic version with paid update service.
(3,480 Views)
Hi there,
There are a few different ways to extract a component's SPICE model:
Transfer > Export Netlist: This will export the netlist for your design. So to export the SPICE model for one component only, simply place it down alone and then export the netlist.
Component Properties > Model tab: This method involves copying/pasting from the Model tab of the Component Properties dialog
  1. Open the Database Manager
  2. Edit the component
  3. Select the Model tab
  4. Copy/paste the SPICE model into a text file
  5. Save with .cir extension
SPICE Netlist Viewer: In Multisim 11, there is also the ability to save a netlist from the SPICE Netlist Viewer, which displays the netlist live within a pane of Multisim
Message Edited by NatashaB on 03-05-2010 01:35 PM
Natasha Baker
R&D Engineer
Join the NI Circuit Design Community
Follow Multisim on Twitter!
(3,473 Views)
