Multisim and Ultiboard
How to create a custom SMT pad?
I would like to use a Philips Lumiled K2 poser led in a design.
This has a hexagonal ashaped pad below the Led.
I created a footprint that works fine, my design looks OK
But I don't like the way I had to make it.....
Let  me explain, I have drawn a haxagonal shape, and made a corresponding paste mask and solder mask...
Then I added a round SMT pin so I could give the new pad a name (so I can use it in my schematics (pin5)
But there should be an easier way...
In the Ultiboard parts editor, when creating a custom pad, I have the possibility to add a 'custom' pad.
Then a window opens to select a custom pad from the database
(check the filter in the screenshot, it says 'custom pad shape'.) but I can't find any custom shape in the databases....
So, next setp, I would like to create my own custom pads, polygonal, and any odd shape smt pad,
And give that one pad  a pin name (attribute Number....)
How can I create such a custom pad?
Best regards
Johan
(4,923 Views)
Accepted by topic author stressed_user
Hi johan,
so you can create a custom pad: Tools, Database,Database Manager.Select filter: Custom Pad Shape. Filter Parts: Createnew part. Custom Pade Shape OK. A design window opens. Now you can create a shape in any form you like, by  place shapes ( polygon or circle or...) Be shure the reference point is inside the shape. File, Save to database. Give a name. File, Close. If you now create a new part you can use the new pad like any other pad in the system.
regards gerhard
(4,908 Views)
Gerhard,
I am using Ultiboard for a number of years, but I would never have found this 'path' to make a new custom pad.
I always tried through the parts editor....
You made my designing-life a lot easier!
Thanks a lot
Johan
(4,870 Views)
