Multisim and Ultiboard
How to convert or export/import pspice .asc format into multisim
I have a simple circuits which had implemented in PSPICE .asc format, those i want to use in NI Multisim, what is the procedure to do that.
(10,594 Views)
Hi there,
Is your pspice.asc format file created by LTSpice? Actually, you can create this simple circuit using Multisim. The following is a tutorial for tansitioning from PSPICE to Multisim. Hope it helps!
Transitioning from PSPICE to NI Multisim: A Tutorial
http://www.ni.com/white-paper/5964/en/
Chen_T
(10,580 Views)
Thanks for your response.
those files are created in LTspice .asc format, we have around more than 200 files which we dont have time to spend for re-implementing in the Multisim, So just i want to know is there any option to get those files in multisim.
Vikram Kumar P
(10,564 Views)
Hi Vikram,
I understand that it is time consuming to re-implement these files, but so far we really do not have this feature in Multisim. Maybe in the near future, we will include this conversion function.
Chen_T
(10,546 Views)
Is still the same issue until now?
Because I would like to import some files from LTspice to Multisim
(4,309 Views)
