06-27-2009 09:18 PM
I'm trying to combine multiple PCB designs into one file in Ultiboard, and I recently find out it has the ability to save pcb design as a componet. Is anyone know how to use this feature ?
Solved! Go to Solution.
06-29-2009 01:04 PM
Hi Sien,
Select the parts that you want to use as a single part, then click Tools > Database > Add Selection to Database.
When you place the parts, you may want to lock them to preserve the layout.
06-29-2009 04:32 PM
Thanks for the reply. I try to save my pcb with all nets locked. However, when I place it on a new design, it results two design rule errors:
1. Unused pin is connected to copper
2. Two objects without nets are too close to each other
I'm wondering how I can solve these two errors.
06-30-2009 08:16 AM
06-30-2009 11:45 PM
07-01-2009 05:41 AM
I don't have exact answer for your question. But i can give reference for you.
http://www.techdockets.com/2009/05/printed-circuits-handbook.html
Here you could find a good book for PCB design concepts.
07-02-2009 08:04 AM
