01-12-2015 09:43 AM
Hi, I'm trying to build an amplifier circuit on Multisim. The schematic looks like this:
At the minute my multisim file looks like this:
The problem is that I can't seem to get an output. I'm relatively new to multisim and don't have a full understanding so I'm not sure where I'm going wrong. Is it a problem with replacating the actual circuit or is it a problem with how the instruments are connected?
Any help would be appreciated.
01-12-2015 12:41 PM
The input signal is grounded. That will do a really good job of making the output look very different from what you expect.
Lynn
01-13-2015 08:08 AM
Hi Dawnn,
As I can see from what you are trying to build, you are missing a variable 100k resistor as far as the circuit is conserned and also it does look like you are trying to use differential measurements however, the grounds of the AI- and your signal don't seem to have the same ground.
I would highly recommend to start off with something simple by using only a couple components, see if you are getting what you would expect then move on and add more components.
Kind Regards,
