03-18-2010 06:10 PM
I just want to put the IC 74HC193 in a typical circuit for it to count from 0 to 15 making a MOD16 UP/Down counter (I want to understand the IC then make the down and up in the same IC later), but when I execute the simulation it freezes on ~CO pin instead of turning the corrosponding lamps to the upcoming number on and off ? Please explain. my work is attached to this post.
thanks a lot
and your help is much appreciated
Note: I'm not allowed to substitute this IC with another model unless the substitute carries the EXACT operation
Solved! Go to Solution.
03-18-2010 06:14 PM
03-19-2010 06:24 AM
03-19-2010 06:32 AM
