08-18-2014 06:37 AM
my icons are too small and i feel like the words are bigger than they should be, does anyone know the reason for this and if yes can you please suggest a solution. thank you. i have attached a picture to show you exactly what i mean.
08-19-2014 03:58 AM - edited 08-19-2014 03:58 AM
Hi Samiashi,
By the looks of things, Multisim is just following the settings on the computer. If you go to Control Panel > Display > Smaller 100% (default), this may help you. This changes the size of your text on your display.
I hope this helps you,
08-19-2014 05:27 AM
Ohh thank you for your help, it worked!
