07-02-2015 07:16 AM
MULTIISM SUITE 12.0
07-06-2015 04:13 PM
Hi QOBOE,
In your attached circuit the enable and load pins on U2 are connected to ground as well as the switches, these should not be connected directly to ground. Also the negative terminal on the AC source V1 and the negative power supply pin on the 741 U4 (net 19) are not connected to ground - they should be.
Making these changes should allow you to simulate properly. I hope that helps.
Jeff
07-10-2015 05:52 AM
Thanks a lot Sir,let me try it right away,thanks again.
07-14-2015 08:41 AM
thanks a lot sir,it did work well,both channels are now oscillating.
