06-02-2014 05:11 AM
I have made a single layer board PCB in ultiboard. (on copper top)
On making PCB, project explorer shows copper bottom & related botom layers. I thouht I can remove these layers in final gerber generation.
But on final step, we can unselect the copper bottom layer option. So fro my single layer board, ultiboard generated gerbers as if its double side board.
How to make settings in ultiboard for this?
06-02-2014 10:14 AM
Hi there,
In the Gerber properties window, you can only check the Copper Top layer and leave other settings as default when you export this Single layer board.
Another way is when you design this Single layer board in the beginning, you can set only one layer at first.
Hope it helps!
