Multisim and Ultiboard
Gain form Bode Plotter
Hi
I'm new member, and i have a little problem with the Gain, i can't see it.
Can anyone please help meBode Plotter
(5,527 Views)
Accepted by topic author d3c0
d3c0,
On the function generator the center pin is ground and the negative (-) pin is actually the inverted waveform.
Also you will likely need to adjust the Frequency range and the Magnitude Range just so the plot maximizes the display of the signal.
Try this and see if you get better results.
Patrick Noonan
(5,525 Views)
