12-05-2013 08:53 PM
I am analyzing harmonic distortion component in an output voltage of a circuit using both Fourier analysis and distortion analysis in Multisim 12 and I realize that the magnitude and phase given by both of the analyses are different. The magnitude and phase from distortion analysis is much smaller than the result from Fourier analysis and I suspect that it has been normalized. Is this true? If so, how has it been normalized?
08-05-2014 08:11 AM
Hi there,
I saw this post has been here for half a year, I was wondering if your problem has already been solved. If not, I will help you to figure it out.
08-05-2014 08:46 AM
Hi. I suspect that the distortion analysis in MULTISIM does not support ABM source. Is that true?
08-05-2014 10:56 AM
Hi there,
We do support the distortion analysis with the ABM source in Multisim 13.01.
01-23-2015 12:04 PM
To me, both of the provided samples (and their Help File descriptions) suggest that the "Distortion Analysis" is seriously flawed!
01-23-2015 12:11 PM
Then please provide details instead of some generic statement.
01-23-2015 01:13 PM
See second plot in "Distortion Analysis for Harmonic Distortion" and third plot in "Distortion Analysis for Intermodulation Distortion" Help Files.
01-23-2015 01:41 PM
You need to be more specific about what you consider flaws. Don't just point to plots.
01-23-2015 01:50 PM
Distortion levels appear to be on the order of 30dB - compare that to the Fourier Analysis results (which appear to be much more reasonable)
01-28-2015 09:49 PM
So, what's next?
