12-04-2009 01:22 PM
Has anyone had any luck exporting to BatchPCB?
I have created a simple circuit as a test to export to BatchPCB. BatchPCB's DRC bot generates an error stating that their are traces that violate the "8 mil traces with 8 mil trace spacing" rule. All traces are well over the 8 mil trace width and spacing.
I think the problem originates from the reference points (cross-hairs) that Ultiboard includes in the Gerber files, see attached image.
I have never seen the above reference points generated from an EDA before. Is it possible to remove these points?
Adam
12-04-2009 01:42 PM
Solved my own problem....
http://forums.ni.com/ni/board/message?board.id=370&message.id=6609&query.id=538004#M6609
This should fix any problems when submitting to BatchPCB.com
Here's to cheap PCBs!
- Adam
12-07-2009 06:53 PM
