09-02-2014 11:06 AM
Hi there,
I ran a simulation and got a plot in oscilloscope, which is in the voltage range of -15V~15V. Then I saved the data that composed this plot. However, when I plotted the trace back in Matlab, I got some strange points with extreme values, like 5e235V, which extended the default vertical axis to a dimension of ten to the power 235. I wonder if Multisim oscilloscope tend to ignore some extremely valued points while showing the waveform? Anyone insight about this?
If screenshots are needed please tell me then I'll update this post. Thanks in advance!
Wilmee
09-03-2014 04:17 AM - edited 09-03-2014 04:18 AM
Hello Wilmee,
Can you share the following information?
1) The Multisim schematics you used
2) The exact steps you performed to save the data (in which order you clicked where)
3) the actual data file you saved
4) The .m code that shows how you loaded your data
Thanks in advance!
09-05-2014 03:24 AM
Hello Wilmee,
Is this issue still active?
If yes, then please let us know.
If no, then please also let us know how you resolved it.
