Multisim and Ultiboard
Custom Labview Instrument with Multisim
I want to use a custom Labview Instrument (Phasor_Diagram) with Multisim 13.0:
http://www.ni.com/example/30200/en/
I copied Phasor_Diagram.llb and the folder Phasor to C:\Program Files\National Instruments\Circuit Design Suite 13.0\lvinstruments but
I can't find the Phasor Labview Instrument in my Multisim.
What is going wrong? How to get this work?
Regards Peter Stolz
Message 1 of 12
(7,673 Views)
Hi Peter,
You may have to restart Multisim but it should be in Simulate»Instruments»LabVIEW Instruments.
Tien P.
Message 2 of 12
(7,669 Views)
Hi Tien,
I have restart Multisim. But I can't find the Phasor_Diagram Instrument in Simulate»Instruments»LabVIEW Instruments.
Regards Peter Stolz
Message 3 of 12
(7,666 Views)
Hi Peter,
Do you see other LV instruments that was installed with Multisim?
You should be able to put the .llb and the Phasor folder in the program files, but there is another place, I extracted the zip file to:
C:\Users\Public\Documents\National Instruments\Circuit Design Suite 13.0\LVInstruments
if you are using an older OS, it goes to docuement and settings:
C:\Documents and Settings\All Users\Documents\National Instruments\Circuit Design Suite 12.0\LVInstruments
Tien P.
Message 4 of 12
(7,659 Views)
Hi Tien,
yes, I see BJT Analyzer, Impedance Meter, Microphone, Speaker, Signal Analyzer, Signal Generator and Straming Signal Generator.
I extracted the zip file to: C:\Users\Public\Documents\National Instruments\Circuit Design Suite 13.0\LVInstruments
But I can't find the phasor_diagramm instrument in Multisim.
Peter Stolz
Message 5 of 12
(7,654 Views)
Accepted by stolzpet
Hi Peter,
It looks that phasor instrument was built using an old LabVIEW version, I rebuit it in LabVIEW 2013.
Tien P.
Message 6 of 12
(7,616 Views)
Hi Tien,
now it works!
Thanks a lot!
Peter Stolz
Message 7 of 12
(7,596 Views)
I have same problem. How can I rebuit in LabVIEW?
Message 8 of 12
(7,093 Views)
HI Maxics,
You can open the instrument .llb you downloaded in LabVIEW Project Manager and then rebuilt it.  Here is a knowledge base how to build a llb file in LabVIEW:
http://digital.ni.com/public.nsf/allkb/E698CCDF9DB336D78625711800762EC0
If you have a problem, let me know which instrument.
Tien P.
Message 9 of 12
(7,091 Views)
Hi Tien,
I have not get success
this tool: https://decibel.ni.com/content/docs/DOC-28563
Message 10 of 12
(7,077 Views)
