05-29-2014 05:53 PM
Hi everyone,
I've the following circuit, which contents a current controlled voltage source:
http://s27.postimg.org/wmpy9uksz/2412424.png
I've found it:
http://s27.postimg.org/7l1nllzgv/Untitled.png
But couldn't know how to deal with it.
Any help?
05-30-2014 08:42 AM
Hi there,
Instead of using the current controlled voltage source, we can place an ABM(Analog Behavior Model) source in Multisim.
After you place the ABM source, double-click it. In the ABM source dialog box, select the value tab. In this value field you can define a mathematical or codniton statement that will act as a stimulus in your circuit.
In this case, let's type: 5*(V(1)-V(0))/2
Here V(1) and V(0) are the net name using the syntax V(<net name>)
Attached is the schematic for reference
Hope it helps!
05-30-2014 09:06 AM
Hi Simosamkun,
You can wire the current controlled voltage source like this;
You can also use an ABM voltage source, it allows you to add an expression and it has the ability to read current through a DC voltage source. In your schematic, you can place a 0V DC source and the current direction should flow through the positive side of the source. You schematic look like this:
