Hi there,
I recommend you start off with the "1P1S" component under Basic/TRANSFORMER family in the database. Set the windings exactly as you have specified (1500 primary and 750 secondary, or simply 2:1). This will give you an ideal, 2-winding transformer (no losses, perfect coupling, no core inductance).
You can then build-up on this model by using some of the advanced options in the 1P1S component, or simply by adding external components like resistors to represent coil resistance (if in series with the coil) or core loss (if in parallel with the coil).
Max
