05-23-2014 06:23 PM - edited 05-23-2014 06:27 PM
HAs anyone assembled Experiment 11 in "Experiments in Digital Fubdamentatls" and got it too work? I'm having one hell of a time doing figure 11-2.
it's a partially built binary to excess-3 code conversion circuit. Can't get it to work!
HELLLPPPP!
Medix
05-26-2014 08:45 AM
Hi Medix,
You should provide more details and post your circuit.
05-26-2014 06:21 PM
This is my dilemma. The book says it should at east operate at this stage so I can work the truth table.
Ughhh...I'm over my head!
05-27-2014 08:50 AM
I don't have the textbook you referred so I don't know what you are supposed to do.
The battery sources are incorrectly wired, the longer line is the positive side and you should connect this side to your circuit, the other side with the shorter line is the negative terminal and you should connect this side to ground.
05-27-2014 10:21 AM
Tien,
Thanks for your reply. THis is experiment 11 in Experiements in Digital Fundamentals. Due to being sick I missed a few classes and my professor has left me struggling with this.
The top circuit is a 7483A bit binary coded and the bottom 7485 magnitude comparator, and a 7404 hex converter. .HAs 5 red LEDs one four pin DIP and a plethora of resisters!
05-27-2014 03:51 PM
Also the solutions needed are that when theDIPs are switched...anything 9 and less should have 0011(3) added. IF it's greaterthan 9 then it needs to add nine(1001). I can't figure how to get the LEDs to reflect that!
Medix
05-27-2014 06:56 PM
OK....figured it out! Took another look at the Truth tables andmade a few realizations!
I'll post the solution here for whoever else needs it for ITT!
Medix
