03-18-2009 05:51 PM
03-27-2009 03:14 PM
03-31-2009 02:44 PM
Hi Jonathan,
After importing the dxf files into Ultiboard, you can just place the cap where it needs to go and run traces to the pads. If the caps are SMT, I don't see a problem generating new Gerber files assuming your dxf files imported correctly. If the caps are THT, you going to have a problem with generating a new drill file. Ultiboard doesn't import drill file so, you are going to have problem merging the new drill location with the one already existed. The drill file is ASIC and you can type in the new drill location. Have a look at this link below to understand the NC drill syntax. But to be honest, I think you should use a Gerber editor to for something like and if you don’t have this tool, see if you board manufacturer have one and see if they can modify the design for you.
http://www.apcircuits.com/resources/information/nc_introduction.html
