06-24-2009 12:12 PM
Hi, in Ultiboard 10.1, i have choose a True Type Font "Freestyle", but the *.gbr-File exported is very Big over 12 MB with only 8 word. how can i change the Polygone traces in this font?
and if not possible to do that, is it possible to make the lines in thisgerber File to be bigger then 0,01mm? it seem to make a lott of thisthin lines to create this Font.
Many thanks for Feed back.
06-24-2009 01:36 PM
Hi Abderrahim,
There is no way to increase the diameter of the line in Ultiboard, but there are ways to reduce the file size. The first thing is to ensure you are exporting Gerber RX274-X, not the D version. Ultiboard is able to export polygons in X that is not possible in Gerber D. A simple test I did reduced a file from 3.7MB to 137KB just from this change. The second thing is to select "Merge Polygons (slow)" in the Gerber properties dialog although I would not expect this to have a significant effect in your case.
06-25-2009 07:26 AM
Many thanks for your Answere,
i choose always the Extended Option, but when i observe the Polygone in GC-Preview for Example, and when i zoom in, i see that there is a lot of small Lines that design or fill the Polygone Font.
The Support of NI told me to use the "paint.net" Software to convert a Font-text to a Picture and to past this monochrom Picture in Ultiboard, is this a Solution?
06-25-2009 01:21 PM
