11-14-2008 01:17 AM
Hi, people i need to simulate my project of 8051 on Multisim.......i used Proteus before this but i need a more enhacned simulator so i switched to MultiSim......now the problem is that i cant simulate a simple as possible circuit containing 8051....... you can view the circuit here
and i loaded a simple external hex file by taking the properties of the 8051 and going to code tab and providing the location of the hex file......my code is just turning the leds on for 3 seconds and then off for three seconds...... can u please guide what can i do to make it work.......plz help.....
or can u people make a sample program for me with steps in photos or in a video.....i'll be very thankful to u for this......
use this code if u feel like: it works perfect on Proteus......
#include<AT89X51.h>
delay() // timer of 1 sec
int d;
for(d=0;d<=1;d++)
TMOD=0x01;
TL0=0xFD;
TH0=0x04B;
TR0=1; // start timer.
while(TF0==0);
TR0=0; // stop timer
TF0=0;
void main()
while(1)
P2=0xAA;
delay();
P2=0x55;
delay();
11-15-2008 12:11 AM
11-15-2008 09:18 AM
I want to pose a question to you about this. I have dabbled with the MCU Module and I am no expert at it by far, but I am experienced in other aspects of Multisim.
The questions I have is this: Were you getting "Timestep Too Small" errors? When you adjusted the default TMAX did this make the time in the lower right hand corner match what you were trying to do?
I will eleaborate on that last question a bit. When you change the time step of the simulator it can speed up or slow down the simulation engine. What it does not do is alter the "circuit time" in the lower right hand corner of the screen. If your LED's were blinking every 3 second of circuit time then after the change it would still blink at the same rate, but you would perceive it to be blinking slower because now the simulation engine is taking longer to get to 3 seconds of circuit time.
I hope I explained that to where it is understandable. I just don't want you to think that TMAX alters any time delays that you have set up in your code.
11-18-2008 06:03 AM
I have no experience with the Multisim controller simulator, but much experience with the 8051-family in real.
For the real circuit you need a crystal circuit at XTAL1 and XTAL2.
greetings,
Lutz
03-31-2009 10:20 AM
hi everyone, i am using multisim for my project work. my problem is whenever i executes movc a,@a+dptr instruction, it makes all bits of port 2 to low level. is it a bug or is there any link between dptr and p2?
please help me, i have very less time.....
06-26-2016 07:35 AM
Hi I am just starting with multisim and assembly programming, I need to do a calcuator usng the 8051+ eeprom + lcd display but i have no clue about how to do it . I will really appreciate some advice
