08-04-2015 11:57 PM
Hello Ive some problems with the 555 Timer. I'm trying to get an defined pulswidth signal out of a current signal. My problem is the circuit should work with 0.25 to 1 Hz on the current signal. I've got it running at 1 Hz but if i try to go lower the timer starts to get crazy.
im a really noob in stuff like that and happy with every little help
i hope someone can help me
thank you
toobi
08-07-2015 08:32 AM
Hi
Can you please specify which signals you receive, and what you would be expecting for lower frequencies?
When you modify the frequency, you just change the frequency of I1?
Corinne
