NI Home
Cart Cart | Help
You are here:
Reply
Aunas
replacement of MC1496 in multisim
what is replacement of MC1496/MC1596 in Multisim when used for modulation and demodulation purposes.
Tien_P
Re: replacement of MC1496 in multisim
yyao
Hi there,
A very simple component which can be used to test modulation/demodulation is the MULTIPLIER component. It can be found in the Sources group and the CONTROL_FUNCTION_BLOCKS family.
I guess you can never find such an ideal component in real life, but its a good place to start prototyping your ideas.
Many semiconductor vendors make analog multipliers and mixers. Have you tried to find these components and their SPICE models?
Yi
Software Developer
National Instruments - Electronics Workbench Group
parsa khare
I need to mc1496 for multisim
sensirinateslakawski
hey Tien P i reaaally need ur help i've no idea about multisim or simulation but i've tried to fallow everything u've said about simulation of the AM modulation i've create a new component ( MC1496) & i changed the pins 7 & 11 & 9 &13 to NC but still i get errors , so if u look at it i'll appreciate it for ever.
ThiCop
Hello sensirinatesla...,
Please look at the post mentioned above...
Kind Regards,
Thierry C - Platinum Applications Engineer - NI Belgium
CLD
If someone helped you, let them know. Mark as solved and/or give a kudo. :smileywink:
