03-23-2014 06:31 AM
Hi, I have circuit of quartz oscillator as it is shown on attachment
Please, I want to know how it works and can I replace the coil of collector L1with resistance and what
The roll of C1?
thank you
03-23-2014 11:15 AM
Have you done any research? A quick on-line search for "crystal oscillator circuits" produces several links to sites describing circuits similar to yours. Before you build such a circuit, make sure the crystal can handle the voltages which will be applied. That circuit tends to operate the crystal at higher power levels than some other configurations.
Lynn
03-26-2014 04:14 AM
Hi, thank you for your reply, you mean by crystal can handle the voltages that applied, transistor prevents the voltages of crystal because it's between collector and tbe base or you have another Idea ?
thank you
03-26-2014 01:35 PM
The collector-base voltage can get large, so if you use that circuit configuration be sure the crystal can handle the power. That circuit typically operates with the crystal at series resonance. Other circuits operate at parallel resonance with the crystal in the base circuit where it operates at lower voltages. Choosing the appropriate oscillator configuration and getting the design to work is the subject of complete books.
Lynn
03-27-2014 03:12 AM
Hi
You mean Generally that circuit can oscillates but not good way, in fact I made small change that capacitor was connected parallel but I think that doesn’t affect
thank you
03-27-2014 01:12 PM
That circuit does work and is used in practice. I just wanted to warn you that it does have the possiblity of delivering higher power to the crystal, so that you did not damage a crystal by using one specified for a different type of circuit. This is one of the kinds of things which a simulation probably will miss or may not model accurately.
Lynn
03-28-2014 12:36 PM
thank you for your reply,sorry if may Our discussion takes long
In fact I tried this circuit on multisim but it didn’t work
About the inductor of collector is it for protection prevents frequencies go throw line of power or has a main roll in oscillation system ? some make it with a nucleus and other no
03-28-2014 02:07 PM
The inductor is an essential part of the oscillator. The impedance of the inductor results in an AC voltage drop across it during oscillation. If the crystal and the collector were tied directly to V1, there would be no feedback to make the oscillator work.
It is often difficult to get simulators to produce the start up behavior of oscillators. In real (physical) oscillators a small amount of noise gets amplified and filtered by the resonant circuit so that feedback occurs at the oscillation frequency. The amplitude builds until some non-linearity prevents further increase. At that point the oscillator is running in its steady state. Probably.
Simulators do not have the noise found in real oscillators. Yes, they can do a noise analysis, but the noise is not present during DC or transient analysis which are used to simulate the oscillation. Sometimes you can get the oscillator to start by applying an initial condition. Try starting the simulation with about 0.5 V on C1.
Lynn
04-06-2014 12:11 PM
Hi
Actually, almost it’s not possible simulation of an oscillator on multisim or other simulator.
when we talk about miltusim, I observed that even when I apply a pulses to simple LC or quartz circuit from signal generator with serial resistor and it doesn’t react
in previous reply You said try start simulation with 0.5v on C1 means I decrease Vb to 0.5 or connecting source voltage to C1? And about the inductor of collector some replaced with resistor I think that it has not to be inductor what do you say ?
thank you
04-06-2014 03:23 PM
I am not sure how initial conditions work in Multisim, but standard SPICE simulators allow you to set initial conditions on components such as capacitors. Here is the section from the manual for the simulator I use:
General form:
.IC V(NODNUM)=VAL V(NODNUM)=VAL ...
Examples:
.IC V(11)=5 V(4)=-5 V(2)=2.2
The .IC line is for setting transient initial conditions. It has two different interpretations, depending on whether the UIC parameter is specified on the .TRAN control line. Also, one should not confuse this line with the .NODESET line. The.NODESET line is only to help DC convergence, and does not affect final bias solution (except for multi-stable circuits). The two interpretations of this line are as follows:
It does not mean changing the circuit or adding a voltage source.
Replacing the inductor with a resistor will change the DC operating point and likely change the gain at the oscillation frequency. The reactance of the 100 uH inductor at 25 MHz is >15000 ohms. If you use a resistor of that value, the transistor would be saturated. If you use a much smaller resistor, the gain will be low.
Lynn
