Multisim and Ultiboard
pin names and numbers do not print with black and white printer setup option
Hello Chris,
A quick question to make sure we're on the same page.
Does the problem not occur when you use the mentioned PCL6-version?
Or did I misunderstand this?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 11 of 14
(754 Views)
@ThiCop wrote:
Hello Chris,
Yes You are right.. after my post you asked for the versions. And I dubble checked the version and how they print.
The PCL6 version on Windows 8.1 print OK !.
Message 12 of 14
(747 Views)
Hello chris,
Would you like me to test if I can reproduce the issue with the PCL5-driver?
Kind Regards,
Message 13 of 14
(745 Views)
No sorry,
At first, since this don't work with PCL6 in windows XP.
And the first time I tried it din''t work in Windows 8.1
But now it do work with the PCL 6 driver it is ok with me...
Just want to share that it work for other peaple wich may have problems..
Thanks my problem is solved.
Chris.
Message 14 of 14
(743 Views)
