03-09-2012 11:57 AM
Multisim V12
Printer HP LaserJet 1320
File -> Print Options -> Print Sheet Setup, check In black/white, OK
Then
File -> Print Preview, shows all elements of the drawing in black white
Then select Print and the drawing prints without pin names and pin numbers.
The same procedure with the black/white unchecked previews in color and then prints all circuit elements
03-09-2012 12:17 PM
Hi HiZTrace,
I used Multisim 12 with the same configuration and printed with a HP LaserJet 4250, but it seemed to be working well for me. There could be some incompatibility issue with your printer driver. A workaround you can try is to install a PDF Converter and print the file in color, then print the generated PDF file in black and white. There are many PDF Converters available, for example, CutePDF Writer (free)
Sorry for the inconvenience.
03-16-2012 11:28 AM
03-26-2012 07:16 AM
I have the same problem (using PCL6 printer driver). Printing to PDF solved the problem. = > Extra work !.
Changing the settings to color (uncheck "In black/white") solves this problem, but the schematic is hard to read due to dithering from the printer (using dots).
Also the view in MS12 is less clear then in MS11 (When zoomed out). I don't know what is changed but is not an advance in my opinion.
Chris.
03-26-2012 08:50 AM
Hello Chris,
Were you able to try the PCL 5 print driver?
You can install them (PCL5 and PCL6) next to eachother, so you can always go back to PCL6 if required.
04-05-2012 08:59 AM
The PCL5 driver fixed the problem !
Chris.
04-05-2012 09:20 AM
It took me some time to troubleshoot this one on my own pc 🙂
04-10-2014 03:57 AM
Hello Again,
The PCL5 driver worked in windows XP.
On Windows 8.1 the PCL5 and PCL6 dirvers both don't print pin numbers... Also the PostScript driver....
I am getting frustraded about this item.... again....
Does anyone has a solution ??? please....
Chris
04-10-2014 01:58 PM - edited 04-10-2014 01:58 PM
Hello Chris,
Which versions of NI CDS (see About window in the Help section) and the PCL drivers are you using on Windows 8.1?
04-11-2014 01:40 AM - edited 04-11-2014 01:47 AM
@ThiCop wrote:
Hello Chris,
Hello ThiCop,
I am using NI multisim 13.0.632
Printer drivers:
PCL5 (v5.5.0)
and PCL5 (61.130.4.12834) UPD versie 5.5.0.12834
and I tried PCL6 Type3 version 6.4.9600.16384 And this is OK when i print direct to the printer !!!
I try to print on a HP laserJet P2055
Thanks for all your effort...
Chris
