11-09-2007 03:34 PM
11-09-2007 03:53 PM
11-10-2007 09:26 AM
I have been going throught your circuit very carefully to find out what was giving the problems. This is why it has taken me a while to get back to you on this. I will outline the changes I made to your circuit below.
1. I removed the digital DCD Hex display and all the digital probes and replaced them with the standard version.(it seems that these were causing some of the problem, but I am not sure why).
2. I increased the voltage to 12V because the 74 series IC's are TTL and I believe they require 12 volts in order to function properly (at least it does in the simulator apparently.
3. Adjusted your wiring because you had segment A not tied to A0 on the IC (This may have been intentional, but I weent ahaead and tied it in). I also added a resistor to ground to the H segment of the disply to light the decimal point. I also cleaned up the wiring a little to make it look better (not that it looked bad, but I just like neat schematics)
The first 2 items is what seemed to cure you problems and the last was just some things I added to it that I thought were needed.
The adjusted circuit is posted below:
11-11-2007 10:12 PM
11-12-2007 04:56 PM - edited 11-12-2007 05:00 PM
11-15-2007 07:25 PM
03-13-2008 11:30 PM
03-14-2008 07:13 PM
I got it going. Take the Analog Ground on Pin 15 of the 74157 and delete it. Replace this with the DGND. This should get it up and running.
This is just a note for everyone reading this post. The Digital components require that VCC or VDD and DGND be placed somewhere or the schematic. I know the documentation says that you don't have to do this if the Digital Simulation Settings are set to Ideal, but I have found that some IC's and Displays just will not work correctly with VCC, VDD and DGND not being present. Please double check that these are present on your schematic as this will cure a bunch of simulation problems. I thought I would share this information so as to maybe save everyone a bunch of headaches when it comes to digital parts.
03-16-2008 04:45 AM
Hello lacy
03-16-2008 08:09 AM
My Profile | Privacy |
Legal |
Contact NI
E-Mail this Page
