NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
Sriram G
Two resistances value depend on one input parameter(like parameters in Pspice)
I would like to have resistances in hierarchical block, which's value has to be changed without entering into hierarchical schematics. Or even two/more resistors who's values will depends on single input parameter(like PARAMETERS option in Orcad/Pspice).
Member
Miguel_V
Re: Two resistances value depend on one input parameter(like parameters in Pspice)
Something very simple which you can use to change capacitance, resistance, and inductance is have a voltage(or current) controlled resistor/inductor/capacitor. Passing a voltage thourgh the blocks will change these variable loads as you wish (you can set it anything like 12.5kohms per Volt for example). You can find these components under Basic-Virtual in the Basic Group. Hope this helps.
Kind Regards,
Miguel V
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
