04-25-2012 04:58 AM
I try to create a simple XSpice model. For example NOT-element.
I wrote MOD and IFS files and compiled it. But element work one time, when i start simulation.
IFS-file
NAME_TABLE: C_Function_Name: cm_testor Spice_Model_Name: testor Description: "A simple gain block" PORT_TABLE: Port_Name: in out Description: "input" "output" Direction: in out Default_Type: d d Allowed_Types: [d] [d] Vector: no no Vector_Bounds: - - Null_Allowed: no no
Mod File
SPICEdev * FAR DynDEVices[] = { &cm_testor_info }; #include #include void cm_testor(ARGS) { if(INPUT_STATE(in) == ONE) OUTPUT_STATE(out) = ZERO; else OUTPUT_STATE(out) = ONE; }
Solved! Go to Solution.
04-27-2012 01:27 PM
Hi Werewolf-Prank,
Can you send us the source code, the compiled dll and circuit you used to test the model.
04-28-2012 06:32 AM
Code and project in the attachment
Thank you
05-07-2012 02:56 AM
Any body can help me?
05-15-2012 03:09 PM
I am sorry for the long delay, I was only able to get you code to work during the intial stage but when the simulation was running the component didn't toggle between high and low. I had to get help from a developer to make this model toggle between high and low during the simulation.
Attached is the .mod, ifs and the dll we created. In the .mod file, we modify your code to include a delay, without the delay Multisim will not toogle during simulation. Also, in the .ifs file, I added a parameter section for the rise_delay paremter.
When you create a component in Multisim using the Component Wizard, in step 1, make sure you select "Digital" under "Component Type" and then select "Til" from the "Component Technology" field.
